Ataraxy1
Aug 21, 2023Tutor
Deleting multiple devices
Is there a way to delete multiple devices from the network ...it has accumulated a ton of dormant devices
Aug 21, 2023Guru - Experienced User
Or factory reset the router and set up from scratch would clear everything out.
What model router do you have?
Ataraxy1
Aug 23, 2023Tutor
Thanks. Would be more trouble to reset that delete them one at a time. Hope someone at NG sees this; the fix in the app should not be difficult.
