kb7vvd's avatar
kb7vvd
Follower
May 01, 2020
Device Manager - No devices shown connected
There are several devices connected to my Nighthawk R7350 but they do not show up in the device manager.  They used to but now they do not.  None of them. I recently installed a new DSL moden to connect to the interent and then plug the Nighthawk into that.  Do I need to open a port or something in my DSL modem to see the devices connected to my Nighthawk?  I am accessing the Nighthawk via its WiFi not the DSL router WiFi.   It was also cooinciendtal that at around the same time I installed the new DSL modem that the Netgear service contact expired.  The router works otherwise just can't see the devices connected to it in the Device manager.
This is about the iOS app feature Device Manager.
  • I am getting the same thing after a new firmware update last week. Not wanting to do a factory reset and having to set up everything again.
  • Same issue with AC2400 and ios nighthawk app.  I think it's relatively recent, may have just happened within the last 3-4 months or so...any solution?  this is the only reason I use netgear
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Community,
    Our engineering team is aware of an issue with the device manager feature not functioning properly on the Nighthawk app and they are currently investigating. In the meantime, please use the web browser to manage your devices.
    Thank you for understanding,
    Christian
    • Nedavis33's avatar
      Nedavis33
      Initiate
      Has this problem been fixed? I’m currently experiencing the same issue
      • michaelkenward's avatar
        michaelkenward
        Who klnows, goven that you have privded no information of what you are seeing.
        The "connected devices"thing comes in many shapes and sizes, depending where you are looking and what you are using.
        So it is unwise to assume that you are seeing "the same issue" rather than something similar.
