globalnobmad
Dec 19, 2024Tutor
Device Manager Nighthawk App
My device manager on the Nighthawk app suddenly looks different. It now has a profile named "home" and my custom names for devices are not there. And it says my parental controls can't be deleted. I ...
michaelkenward
Dec 27, 2024Guru - Experienced User
Which app? iOS or Android?
Which app version?
Is this a local Connected Locally or Anywhere Access.
And the router's firmware version? Apps and firmware are intimately tied together.
Just another user with time on their hands.
globalnobmad
Dec 27, 2024Tutor
Thanks for the response.
IOS app version 2.42.0.56
Firmware version 1.0.1.60
- michaelkenwardJan 01, 2025Guru - Experienced User
Firmware version 1.0.1.60Anywhere Access or Connected Locally?
- globalnobmadJan 01, 2025Tutor
I've tried with both. Same results.
- Jarga5Feb 14, 2025GuideAny luck getting this fixed? I’ve always seen this white screen. Last week I saw the black one filtered by band with the option to toggle access which was an AWESOME upgrade. But now it’s gone. How do I get it back??
