globalnobmad
Dec 19, 2024Tutor
Device Manager Nighthawk App
My device manager on the Nighthawk app suddenly looks different. It now has a profile named "home" and my custom names for devices are not there. And it says my parental controls can't be deleted. I ...
designfly
Dec 28, 2024Aspirant
I too have the same issue and reported it to Netgear support with no help
The "Home" profile now shows every device that was ever connected (116 devices)
But I only have 10 connected devices. So I tried deleting stale devices for the list and it basically locks up the app.
This all started after they added the parental controls to the app....
I back dated my router firmware to the previous version and everything was back to normal. But Netgear in all their wisdom does an "auto update" which you can't stop on my model router. So the next day I am back with the same problem.
App is current version
Firmware on router is current version
So the problem gets worse because the new profile shown in white will not let you manage device list so security goes from 96 to 46....and Netgear does not seem to care
globalnobmad
Dec 28, 2024Tutor
Yes, the same issue!
