RNick
Feb 14, 2025Aspirant
Device manager no longer works after updating firmware on RAX5 Firmware version v1.0.9.44_1
The device manager on my iPhone app (version 2.43.1.1) no longer works after performing a mandatory firmware update v1.0.9.44_1. Is there a problem with the firmware update?
Feb 14, 2025Guru - Experienced User
What do you mean by no longer works?
What iPhone model do you have?
What iOS is loaded on the phone?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Is Protection Engine enabled on the routers web page under Advanced tab/Security?
RNick
The app no longer shows any devices, it was working fine before the firmware update.
iPhone SE 2022
IOS 18.3.1
Do not see Protection engine under advanced/security. Access control is enabled and set to allow.
Mac address on iPhone is set to rotating
