theedge21
May 23, 2021Tutor
Device manager not displaying devices
Whenever I access my router from the nighthawk app (on my android), I'm not able to see my devices from the device manager. When you select it it seem to open a Parental control page and it display "...
smckee
Aug 11, 2021Aspirant
I am having same problem no matter how I connect to router no devices are shown connected.
- Guyoncouch02Dec 08, 2021AspirantHi all. Running nighthawk r6700v3 .. FW v1.0.4.120.
Since that firmware update, i am not seeing my attached devices anymore. This is on the nighthawk app or in the web GUI. Any thoughts on this? I haven't found anything on it.. I'm thinking it's firmware related but unable to confirm. Thanks.- FURRYe38Dec 08, 2021Guru - Experienced User
Did you factory reset the router and setup from scratch after that last FW update?
Since that firmware update, i am not seeing my attached devices anymore. This is on the nighthawk app or in the web GUI. Any thoughts on this? I haven't found anything on it.. I'm thinking it's firmware related but unable to confirm. Thanks.- Guyoncouch02Dec 08, 2021Aspirant
ya know i read about it after i posted. do we know any reason why a factory reset is required after this FW update was pushed out? does the reset revert to a different FW version after the reset? thanks for the insight
