theedge21
May 23, 2021Tutor
Device manager not displaying devices
Whenever I access my router from the nighthawk app (on my android), I'm not able to see my devices from the device manager. When you select it it seem to open a Parental control page and it display "...
Oats467
Dec 24, 2023Aspirant
Is there a solution to this problem?
michaelkenward
Dec 24, 2023Guru - Experienced User
If you mean invisible attached devices, there can be different solutions based on what you want to achieve, what you are doing, the Netgear devices you use and other factors.
If you need help with a particular system, then rather than latching on to the end of an inconclusive conversation that has been running for some time, it might be better to start your own fresh contribution, including as much detail as possible.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- Oats467Dec 24, 2023Aspirant
I am trying to use access control, when I log in to the router on my computer it says to use the app.
When I use the app I was getting nothing, just wanted me to set up parental controls.
I updated to the latest firm ware on the router and now I can see devices on the app.
But I still don't see how to turn on access control or how I can allow to devices in.
Also none of the devices in the list have any name next to them, before they had a description.
