ChrisR11
Mar 15, 2024Tutor
Device Manager not showing any connected devices
I am using the NightHawk app with my NightHawk router. The device manager used to work fine. I believe there was an update recently. Now the device manager doesnt work, shows no devices connected. I h...
michaelkenward
Mar 16, 2024Guru - Experienced User
Which version of the app? What mobile platform? (iOS or Android?)
Which Nighthawk router?
What firmware version?
Claims of "the latest" is not a reliable or helpful indicator when troubleshooting. It depends on how you check the firmware version.
People turn up here all the time mistakenly making the "latest firmware" claim.
The on-board check for new firmware is unreliable. It can miss updates, especially when you are a long way behind the latest. It can also be a while before updates hit the automated update servers.
The best way to check is to visit the support pages for your device and to look at the library of available updates.
Support | NETGEAR
Feed in your model number and look for firmware for your device.
The release notes should also tell you how to manually update the firmware.
- ChrisR11Mar 16, 2024TutorMike,
IOS: 17.3.1
Hardware Version: RAX43
Firmware Version: 1.0.16.132
My claim of having the latest firmware is based on using the product as intended for the consumer, via its built in update checker.
Additionally, I can see the connected devices when logged in directly to the router via local IP. So this appears to be localized to the ios app. Also looks like this bug has been reported a few times in this forum over the last few years.
Clicking device manager in the app just shows 0 devices and says “sorry, your device list failed to load. Try again later”.- michaelkenwardMar 16, 2024Guru - Experienced User
ChrisR11 wrote:
My claim of having the latest firmware is based on using the product as intended for the consumer, via its built in update checker.That should work, but it can fail for various reasons.
In your case, it is behaving as it should.
Additionally, I can see the connected devices when logged in directly to the router via local IP. So this appears to be localized to the ios app. Also looks like this bug has been reported a few times in this forum over the last few years.If "via local IP" you are using a web browser and the graphical user interface (GUI), that goes nowhere near the Nighthawk App.
The app can use a local connection via your own wifi network, or Anywhere Access via MyNetgear and the Netgear cloud system.
Also looks like this bug has been reported a few times in this forum over the last few years.Afraid so, and the iOS versions seems to be especially fragile.
I have not seen any thorough and reliable way of fixing this. You can try removing and reinstalling the app. Or, if the iOS app is like the Android version, shake the phone and report the problem.
- ChrisR11Mar 16, 2024TutorOk thanks. Anyone else have any feedback? Perhaps someone from NetGear can provide guidance on what the proposed solution is?
