matthelm75
May 03, 2020Initiate
Device manager on iOS not working ('No Device Found!)
Just noticed this problem today. Everything is connected, but on the Nighthawk App, when I select the Device Manager, it says that 'No Device Found' although everything is working. I checked t...
- Jun 03, 2020
Problem was the iOS app. Once that was updated and I downloaded the latest update - then it worked.
HomeITgotoguy3
May 04, 2020Tutor
I'm having the same issue. Please fix ASAP.
- michaelkenwardMay 04, 2020Guru - Experienced User
Sniff around and you will find many many reports of the same thing.
Lots of different hardware hit.
- JamesENicholsonMay 29, 2020Aspirant
This feature worked initially when I installed the system a few weeks ago. Either a firmware upgrade or an iOS app upgrade has rendered the "connections" invisible. I can no longer see the 10-15-20 devices I have connected via wifi. Annoying.
- Christian_RJun 03, 2020NETGEAR Employee Retired
Hi JamesENicholson,
Welcome to the community! May you provide the following info.Product Model:
Firmware Version:
App version: (iOS/Android)
Thanks,Christian
