matthelm75
May 03, 2020Initiate
Device manager on iOS not working ('No Device Found!)
Just noticed this problem today. Everything is connected, but on the Nighthawk App, when I select the Device Manager, it says that 'No Device Found' although everything is working. I checked t...
- Jun 03, 2020
Problem was the iOS app. Once that was updated and I downloaded the latest update - then it worked.
michaelkenward
May 04, 2020Guru - Experienced User
HomeITgotoguy3 wrote:
I'm having the same issue. Please fix ASAP.
Sniff around and you will find many many reports of the same thing.
Lots of different hardware hit.
JamesENicholson
May 29, 2020Aspirant
This feature worked initially when I installed the system a few weeks ago. Either a firmware upgrade or an iOS app upgrade has rendered the "connections" invisible. I can no longer see the 10-15-20 devices I have connected via wifi. Annoying.
- Christian_RJun 03, 2020NETGEAR Employee Retired
Hi JamesENicholson,
Welcome to the community! May you provide the following info.Product Model:
Firmware Version:
App version: (iOS/Android)
Thanks,Christian
- matthelm75Jun 03, 2020Initiate
- garyindiana4612Jun 04, 2020Aspirant
R7450 My Netgear App has bugs, 1 can NOT connect remotley, 1 can change icons in the DM
We installed the newest ver app and ver in the router still not working
Do I need to take the router back?R7450
