matthelm75
May 03, 2020Initiate
Device manager on iOS not working ('No Device Found!)
Just noticed this problem today. Everything is connected, but on the Nighthawk App, when I select the Device Manager, it says that 'No Device Found' although everything is working. I checked t...
- Jun 03, 2020
Problem was the iOS app. Once that was updated and I downloaded the latest update - then it worked.
Christian_R
Jun 03, 2020NETGEAR Employee Retired
Hi JamesENicholson,
Welcome to the community! May you provide the following info.
Product Model:
Firmware Version:
App version: (iOS/Android)
Thanks,
Christian
matthelm75
Jun 03, 2020Initiate
- garyindiana4612Jun 04, 2020Aspirant
R7450 My Netgear App has bugs, 1 can NOT connect remotley, 1 can change icons in the DM
We installed the newest ver app and ver in the router still not working
Do I need to take the router back?R7450
- michaelkenwardJun 04, 2020Guru - Experienced User
Who knows what your problem is?
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one, especially in a Solved discussion.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
- ErikrussJul 05, 2020AspirantI am dealing with the same problem.
Device Manager, no devices found..
IOS - would greatly appreciate some guidance.
Thanks- Christian_RJul 09, 2020NETGEAR Employee Retired
Hi Erikruss,
I would recommend reinstalling the Nighthawk app and rebooting your router.
Christian
