glsrdaz
Feb 06, 2023Aspirant
Device Manager shows white background & stupid counts
App ver 2.23.0.2673 Firmware v 1.0.3.32 Normal black background now replaced by white screen with no band groupings. Device count may be accurate or may be 0, -1, etc. Initially noticed Feb 5, 2023...
glsrdaz
Feb 15, 2023Aspirant
Thanks for the quick reply.
The display you present is the displayed characteristics my devices showed from Aug 2022 thru approx Feb 5, 2023.
I currently get the white model on all the devices listed in the thread...Samsung phones & tablets, iPad, Windows 11 Pros.
Feb 15, 2023Guru - Experienced User
Seems that for the MK series systems, this is by default with a White theme for the Device Manager. I see same thing on my MK series system as well on Android. If I change over to a non MK system, I have a XR700 online on a separate line, the device manager display is dark themed.
I'll pass this on to NG and see what there intended design is going to be for the MK system or if this is just a bug.
- michaelkenwardFeb 15, 2023Guru - Experienced User
Not here.
I have a mix. No white theme on MK or R7XXX. That's "Connected Locally".
- FURRYe38Feb 15, 2023Guru - Experienced User
Ok, I'm remote thru Anywhere Access. Possible local could effect this. You see any different with using AA?
Ya something on my iphone here at work thru AA. I'll check local when I get home soon.
michaelkenward I posted something regarding your MK system. Please take a look there. đ
Thank you Sir.
