waterboy7777
Jan 27, 2015Follower
dgnd3700 v1 and genie
Hi!
Is it possible to use the modemrouter dgnd3700v1 with the app genius HD? (from IPAD)
Thank you in advance for your help.
best regards
1 Reply
- covillen1ApprenticeThere is a App for the IPad,
http://www.netgear.com/home/discover/apps/genie.aspx
Here is a list of supported routers
http://kb.netgear.com/app/answers/detail/a_id/24686/~/netgear-genie-supported-routers
I didn't see dgnd3700 v1 but I did see dgnd3700 v2. You can always try and find out how well it works.
