MYouell
Dec 28, 2023Follower
Disable Anywhere Access on RAX50 Using Nighthawk App
My Router: Nighthawk RAX50
Firmware Version V1.0.16.132_2.0.92
Download the nighthawk app on your mobile and make sure your router is connected. Go to the menu drop down on the top left of your screen and right below the NIGHTHAWK heading is you device list. Select your router and from there you can disable the anywhere access by selecting " locally connect".
