cboshdave
Oct 06, 2016Aspirant
Disable Live Parental Controls button
I have setup netgear genie which seems good on the surface, but my kids just figured out another weakness. There is a netgear genie icon on the desktop. Click it, select parental controls and low a...
bennettg
Jul 21, 2017Aspirant
So Dexter, does it look like a password protect will not be added to the desktop app and I should just delete it and use the web interface? I just want to know if I should wait for this seemingly easy fix/update or unistall and use the web only.
Thanks
