rjsrouter
Feb 05, 2025Aspirant
disabling SIP AGL in Netgear router
I have a router I got in 2020. I was able to log in then via a Web browser (Google Chrome) at the www.routerlogin.net site, but I see no login options there or on the www.routerlogin.com. Clicking...
rjsrouter
Thanks michaelkenward for replying!
Yes, the instructions say I need to go to www.routerlogin.net in order to log in, but I do not see the place where I can enter the login credentials. Since you can, could you please point me to the spot on that page or provide the URL? The router is plugged into a T-mobil internet router. Everything is working, the modem and router is working, I just need to be able to log in to see the router configuration. The troubleshooting site on the VOIP service points out that the SIP AGL ( a filter in the router) may need to be disabled, but here is my situation:
I try to use my VOIP line to call a cell phone and leave a voicemail. I get to the voicemail greeting and leave a message but then the voicemail automated voice says "nothing has been recorded." All others can call and leave a message, only this device can't, so I am only looking into local causes (old phone, router setting/SIP AGL, etc.). It may not necessarily be the VOIP service since I can call others and leave voicemail on other phones, and others can call my VOIP phone and cell phone and leave messages. It's just between the VOIP phone and my cell phone.
So, I am simply going down the troubleshooting instructions -- not verbal instructions -- and see if disabling the SIP AGL might fix it. But I cannot log in to my router and the nighthawk app does not have a way to do the same. I have had the Tmobil doing its testing and I have yet to hear back from the VOIP service to get back to me. In the meantime, I thought I'd try a few things I can...except I can't login to the router. Thanks!
michaelkenward
Feb 06, 2025Guru - Experienced User
What page?
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
If you have two routers on your network, that is a recipe for chaos. One is that attempts to login to the Netgear router get diverted.
You don't tell us what the modem is or what the Mesh router is but this is probably a consequence of stringing two routers together.
In this case, the Mesh probably chose its IP address range of 10.0.0.X because it saw that something else had already taken over its preferred address range of 192.168.1.X
Two routers on your network can cause headaches. For example, you can end up with local problems with addresses on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
Just another user with time on their hands.
- rjsrouterFeb 06, 2025Aspirant
Thanks @michaelkenward!
There is only one router (no mesh either), and I am coming to the conclusion that it --- and the SIP AGL -- are not the problem because the VOIP device can call outside to other phones on other services. Still, I'd like to be able to look at router configurations, and one of the links you provided (https://kb.netgear.com/1097/How-can-I-regain-access-to-my-NETGEAR-router) may be able to help. I am not at home, so I have to wait until I get home to connect the PC to the router (instead of the model), and then get in that way. Thanks for detailing the issues with double routers (not the case here) and Double NAT. The modem is what Tmobile uses to access its home internet service with two LAN ports -- one for the PC and the other one I used for the router. I haven't explore the bridge and modem only modes, so thanks for that. I will explore that also. I will let you know what I found out.
- michaelkenwardFeb 06, 2025Guru - Experienced User
I'm confused. You said earlier:
"The router is plugged into a T-mobil internet router."
What make and model is that?
....I am coming to the conclusion that it --- and the SIP AGL -- are not the problem because the VOIP device can call outside to other phones on other services.It always helps to track back to the real problem at hand. In your case, you seem to be trying to fix "SIP AGL". But you really want what is "preventing voice to be recorded on voicemail of a smartphone". Your VoIP carrier may well suggest this, but often they are just flailing around looking for someone else to blame when things go wrong.
Disclaimer: Just another user with time on their hands.
Sorry, I misspoke. The modem is the TMobile unit (I do not have the model with me now, it's at home), and the NETGEAR NightHawk is the router (and range extender in one). I will connect the PC to the router, and maybe I can look inside that way. Thanks for all your suggestions michaelkenward
