JC21
Apr 05, 2018Aspirant
Disney Circle stops working frequently on R7000
Disney Circle Premium stops working frequently on R7000. The only way to fix it, that I've found, is to restart the router. My family is not happy, as they are often blocked from the internet. ...
YrRoT
Jan 26, 2019Initiate
Hi Martin,
Thank you for posting your reply to Dexter. I'm curious as to what Dexter's suggestion was in the PM. Would you care to share? Having his responses in PM doesn't allow me to see both sides of the issue.
Either way, thank you for taking the time to post. It is helpful for me, as I am having the same issues you did with Netgear/Circle.
Best regards,
Torry
martynz
Jan 26, 2019Star
It was just a request for us to contact them. Standard support request. While it's nice to want to fix it 1) I had already spent many hours on it , reset the router and firmware and 2) The fact that this can actually happen to a nuimber of people and not be a concern to them shows me that Parental safety is not a primary concern for them - and it could happen again. I cannot let my children be exposed to that possibility. I am using untangle on a Linksys Router. Not quite as nice as Disney - but more robust.
