Curt42
Jan 31, 2016Follower
Display Access Control List in NetGear Genie after FW Update V1.0.2.78
Hi. I recently upgraded the firmware of my NetGear wireless router model WNDR3700v4 to FW level V1.0.2.78. I noticed some menu changes and after poking around, found the button to the ACL menu. ...
DexterJB
Feb 01, 2016NETGEAR Moderator
Hi @Curt42,
You should still be able to specify the name of a connected device through Access Control. You can do this by accessing the router's UI > Advanced > Security > Access Control > Select the check box on the left of the connected device (assuming you already had Access Control enabled and the device connected to the network) > Select Edit on top of the table > Assign your preferred device name > Apply. You should now see the new device name.
You can also do this using the NETGEAR Genie program/app. Once you have it opened, select Network Map > Select the device > Select Modify > Input your preferred device name > Apply. This is also one way to manage the Access Control feature of the router. You can download the program/app for your specific device using the link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
