polyrob
Apr 10, 2016Aspirant
Dynamic DNS updating IP address that doesn't match router's IP
This may have been answered elsewhere but I couldn't find a similar question. I'm not talking about NAT here. I understand my devices have different IP addresses that are issued out by the router (...
- Apr 10, 2016
Yes, there two layers of NAT, one by your router and one by the ISP. And, yes, that means that Dynamic DNS won't work. One way to work around that is to connect your home server to a VPN provider.
You would have to check with your ISP about the nature of your IPv6 address. If it's fairly stable, then there are Dynamic DNS providers out there that support IPv6.
TheEther
Apr 10, 2016Guru
You may think you are not talking about NAT, but your situation actually involves NAT. Your ISP is doing Carrier Grade NAT. :smileysurprised:
You may be wondering, "Why is my ISP doing NAT?" You see, there are actually no more public IPv4 addresses available. Unfortunately, your ISP doesn't have enough public addresses to give one to every customer, so they have to resort to using NAT. Your ISP actually posted about this in their blog (link).
IP address 100.65.140.24 belongs to subnet 100.64.0.0/10, which is a private address range set aside for ISPs to perform Carrier Grade NAT (CGN). See IETF RFC 6598 (link). Your ISP assigned it to your router but it is not a public IP address.
IP address 199.87.86.198 is a public IP address. Technically, it doesn't belong to you. Rather, it's shared by you and everyone else in your ISP's NAT domain.
The one mystery is why you can connect to your home server using 100.65.140.24. 100.65.140.24 is not reachable from the Internet. One possibility is that you are accessing it from somewhere else inside your ISP's NAT domain, like a neighbor's place who also has the same ISP.
Moving to IPv6 will certainly get you out of the CGN mess.
Hope this helps.
BARNES
Apr 10, 2016Apprentice
Dang, I learn something new everyday in networking! Number one reason I enjoy networking!
If that was my situation, I would probably just buy a single static ip from my isp... Without checking I'm pretty sure you could setup your no-ip domain names using a static, else remember that ip likes its your phone number or buy a qualifing domain name and point to your home network.
