jbrickey
Jun 01, 2017Initiate
Enable Remote Access Fails - "Incorrect request format, try again."
I have been unable to enable remote access w/in the Genie App. Whenever I try I get an failure error indicating "incorrect request format, try again.". Anyone else seen this?
- Jun 09, 2017
I found that my model is not supported AC1750 (R6700). So there is that... :-)
DexterJB
Jun 07, 2017NETGEAR Moderator
1. What is the model number and firmware version of your device?
2. What version of the Genie app do you have installed?
3. Have you tried using another device (Android, iOS, PC)?
4. Have you tried resetting the router?
Dexter
Community Team
- jbrickeyJun 09, 2017Initiate
