krb454
Jul 08, 2019Guide
Enable Remote Mgmt Error
I am trying to enable Remote Management from the Nighthawk app and I'm receiving an error that says: "Some error occurred while enabling/disabling remote managemnt" I've rebooted, updated fi...
michaelkenward
Jul 09, 2019Guru - Experienced User
Have you enabled Remote Management on the R8000P?
There is support for the R8000P, including a manual and firmware, somewhere at the end of this link:
>>>> R8000P | Product | Support | NETGEAR <<<<
See the section Set Up Remote Management.
- krb454Jul 09, 2019Guide
If you are referring to the Remote Management setting through the web interface. Yes.It is enabled.
- michaelkenwardJul 09, 2019Guru - Experienced User
I am referring to the bit in my message.
Yes - remote management is enabled through the web interface as outlined in the documentation that you sent. It has been enabled all along. The issue I am having is enabling Remote Management through the Nighthawk mobile app.
