xxxxxxx's avatar
xxxxxxx
Guide
Oct 27, 2015
Error: "Login failed. The router response timed out"
When I run Netgear Genie and attempt Router Login, I get this error: "Login failed. The router response timed out."
The cable gateway's IP is 192.168.0.1. I also tried 10.51.103.9 (which apparently is the IP address in the internal link between the cable modem part of the gateway and the router part of the gateway).
I can log in as "admin" via Firefox at either IP address.
Windows Firewall does not appear to be the problem.
I'm running Netgear Genie in an attempt to update the firmware, but this problem is stopping me.
Thanks for your help,
Mark.
  • Judging from your other posts, it looks like you have a CG3000D. I don't think Netgear Genie is designed to work with it. Nor do I think the firmware can be upgraded by the user.
    • xxxxxxx's avatar
      xxxxxxx
      Guide
      It's a DOCSIS-3. The firmware should be upgradable. Other people have done it. My cable ISP (Warner Roadrunner) says it will not push a firmware update because it's my hardware. Warner says to contact Netgear. When I contact Netgear support, the people in India attempt to extort money from me.
      A simple firmware update should be downloadable. I thought Netgear Genie might be the way to accomplish that, but Netgear Genie will not run properly.
  • I didn't say that the firmware couldn't be upgraded. I said that it couldn't be upgraded by the user. AFAIK, modem firmware is usually managed by the ISP because they often customize it to work for their network. I once owned my own Motorola SB6141 cable modem and firmware was not generally available to download and install. Fortunately, my ISP had no problems pushing new firmware to it. It was in their list of supported modems.
    In fact, I just looked at Time Warner's list of supported modems and the CG3000D is listed. More importantly, they state that the firmware is "managed and periodically updated by Time Warner and is, therefore, not configurable by end users."
    I really doubt that Netgear is going to have generic firmware available to install. I think you should pressure your ISP to upgrade your modem's firmware. You should point them to the page with the statement I quoted above. Do a web search for "But your own Internet modem Time Warner Cable".
  • Sorry autocorrect messed up. It should be "Buy your own Internet modem Time Warner Cable".
    • xxxxxxx's avatar
      xxxxxxx
      Guide
      That's a N450 CG3000Dv2. My gateway says "CG3000D". It used to be on Time Warner's approved list.
      PIN = 37319809
      Serial # = 2CG126UT285AC
      UPC = 606449071740
      HW Ver = 2.01
      SW Ver = V5.5.2RG-05B
      I believe "SW Ver" is firmware (not SW). I read in a forum somewhere of a person who was able to update to V5.5.4 and it fixed problems they were having.
      However, this may all be moot. I recently removed Intel PROSet WiFi software and my connection has become much more stable. The Intel PROSet apparently was molesting the gateway causing frequent disconnection. Sigh! In persuit of "It should just work", Windows & Intel & Netgear Genie try to fix stuff in the background without user help (or even letting the user know what's going on), and they apparently just step on each others toes, and stuff keeps breaking. "It should just work" is fine when it works. But when it breaks, "It should just work" leaves users with no tools and with their fingers broken.
      PS: I should add that, just because a gateway is on Time Warner's approved list, that doesn't mean that Time Warner will push out firmware updates. They say that they will not do it because of "liability". Blame the lawyers.
      • TheEther's avatar
        TheEther
        Guru
        Good to hear that you got your immediate problem resolved.
        As far as liability, no disrespect intended, but that's nonsense. If anything, they could be held liable for willfully refusing to do what they said they would do on their own website.
