Immy001
Nov 10, 2022Aspirant
Ethernet connected MS60 shows amber and no longer showing in the network map
Hi Not sure if FW related but Ethernet connected MS60 shows amber and no longer showing in the network map BUT it is showing as a device in the device list connected to the MR60 Was all working fi...
Nov 10, 2022Guru - Experienced User
Please post a screen capture if what your seeing on the Network map in this thread.
Is the MS connected directly to the back of the MR or is there a LAN switch in between them?
What CAT# LAN cable are you using? CAT6 is recommended.
What mobile platform are you using? Apple or Android?
Immy001
Nov 11, 2022Aspirant
Hi
MR60 device list below
MS60 in list has amber light and IS NOT showing in the network map. I can ping it and WiFi is working (slower than normal)
I am using iOS 15.6.1
Firmware is up to date
Wiring is MR60 - Switch (Gigabit Dlink) - ethernet cable (not sure of spec) - Wall socket - Switch (Edimax, going to change this to Netgear tomorrow)
I bought another MESH product (TP Link Deco) to test the connection, it worked fine !
MS60 (amber light) doesnt show in map but IS listed under MR60
