DaveNetuser's avatar
DaveNetuser
Expanding a ReadyNAS 314 with another ReadyNAS 314?
Hello all. I have a ReadyNAS 314 and would like to expand by adding an expansion unit. Can I just add another ReadyNAS 314, or do I need the specific ReadyNAS Expansion Unit?
  • DaveNetuser's avatar
    DaveNetuser
    Nov 29, 2017
    Thank you. I will do that. Your breif response was much appreciated. Thanks so much.
  • michaelkenward's avatar
    michaelkenward
    You would do better to post your question in the forum section dedicated to NAS.
    ReadyNAS Network Storage - NETGEAR Communities
    If you just want more storage, and have spare LAN ports, you can just buy another box. If you want them all to have the same network location, then you may have to buy a new NAS that will accept more drives. But setting that up may be complicated.
    You'll probably get more intelligent answers than I can offer in the right forum.
      DaveNetuser
