richlife69's avatar
Oct 27, 2015
Fault/error with Genie for Windows Net Map
This is more of a problem report for NetGear Genie.  The Android version of Genie works fine.  On two devices, it creates the Network Map and includes my Netgear WNCE2001 network extender as a device...
  • DexterJB's avatar
    DexterJB
    Nov 03, 2015
    Hi richlife69,
    Thank you for providing the information. I believe the device involved here as shown on the NETGEAR Genie program is an EX6200 instead of the previously mentioned WNCE2001. This is indeed something that needs to be looked at by engineering since the network map is quite inconsistent in accurately displaying the type of devices that are connected. However, it is good that it shows the correct IP addresses for the individual devices as it should. Rest assured, we will continue to work on the accuracy of this feature based on your feedback. I highly recommend keeping the NETGEAR Genie programs up to date on your devices for possible fixes.
    Dexter
    Community Team
