richlife69
Oct 27, 2015Star
Fault/error with Genie for Windows Net Map
This is more of a problem report for NetGear Genie. The Android version of Genie works fine. On two devices, it creates the Network Map and includes my Netgear WNCE2001 network extender as a device...
- Nov 03, 2015
Hi richlife69,
Thank you for providing the information. I believe the device involved here as shown on the NETGEAR Genie program is an EX6200 instead of the previously mentioned WNCE2001. This is indeed something that needs to be looked at by engineering since the network map is quite inconsistent in accurately displaying the type of devices that are connected. However, it is good that it shows the correct IP addresses for the individual devices as it should. Rest assured, we will continue to work on the accuracy of this feature based on your feedback. I highly recommend keeping the NETGEAR Genie programs up to date on your devices for possible fixes.
Dexter
Community Team
DexterJB
Nov 03, 2015NETGEAR Moderator
Hi richlife69,
Dexter
Community Team
richlife69
Nov 03, 2015Star
The extender icon certainly looks like an EX6200. I had assumed it was just a "symbolic" icon, not intended to be an actualy image of the device. So no, it definitely does not look like a WNCE2001 which looks more like a large clam shell. My device has only one ethernet port and is an N device. The EX6200 is a 5 port device and is AC.
But I guess you know that. If Genie is trying to show images of the actual (or similar) device, that's great. Good to know my info may help. Apparently my wife wants to buy a new printer. If wifi, it needs to be AC level as it's obvious the world is moving (has moved?) away from N level.
Rich
