richlife69
Oct 27, 2015Star
Fault/error with Genie for Windows Net Map
This is more of a problem report for NetGear Genie. The Android version of Genie works fine. On two devices, it creates the Network Map and includes my Netgear WNCE2001 network extender as a device...
- Nov 03, 2015
Hi richlife69,
Thank you for providing the information. I believe the device involved here as shown on the NETGEAR Genie program is an EX6200 instead of the previously mentioned WNCE2001. This is indeed something that needs to be looked at by engineering since the network map is quite inconsistent in accurately displaying the type of devices that are connected. However, it is good that it shows the correct IP addresses for the individual devices as it should. Rest assured, we will continue to work on the accuracy of this feature based on your feedback. I highly recommend keeping the NETGEAR Genie programs up to date on your devices for possible fixes.
Dexter
Community Team
DexterJB
Oct 28, 2015NETGEAR Moderator
Hi richlife69,
The Windows NETGEAR Genie program may be identifying the actual adapter (WNCE2001) only which receives the IP address from the router.
Dexter
Community Team
- richlife69Oct 29, 2015Star
Yes. That's right. But my point is that the Android version recognizes both the adapter and the device plugged into it -- they have different ip addresses in the same subnet.
Also, I now have seen that the Windows map sometimes shows the adapter ip and other times the device ip. They at times swap while I'm watching.
Plus, if I open Genie on my desktop, I get an interface that looks similar to the Android app. But if within that Windows map display I click on the router icon to see the detail and then click on the ip (in this case 10.0.0.1), I'm prompted again for the username and pw. Entering that, I then get a new Genie - like interface but with tabs for Basic and Advanced. (I think it's Basic -- tapping on my phone now.) Instead of a Map button, this interface offers a Connected Devices button which takes me to a table of the devices shown on the Map. In the table are included BOTH devices (adapter and receiver) with their names and ip asdresses. In other words, it has the same info as is shown on the Android Map display.
So it seems obvious that the Windows Genie Map display does have a bug. It should show the adapter and the connected receiver as two separate icons.
- DexterJBOct 29, 2015NETGEAR Moderator
Hi richlife69,
1. Does the receiver have a separate adapter other than the WNCE2001?
2. Please provide a screenshot of the following:
- Android app network map showing both the adapter and the receiver
- Windows app showing the adapter with different IP's
- Windows app showing the connected devices table with both the adapter and the receiver
Dexter
Community Team
- richlife69Nov 03, 2015Star
The receiver has an ethernet port which is connected to the extender.
The first shot shows the map with both the network extender and the AV receiver. After a few minutes, the map looses the extender and shows the receiver twice -- but each has the right ip addr. (This last change started happening after my original post.)
Sometimes the ip displayed is the extender, sometimes the receiver.
You can see that both extender and receiver show in this table. To get to this browser interface, I click on the router in Genie, click on the IP addr and then enter the userid/pw to access the router. So I end up with Genie running standalone and running in the browser (Chrome) tab. I can swap the focus between them.
