Dogdad7
Oct 23, 2022Aspirant
Filter options changed?
My router is a R7000 and noticed that the 2.4 and 5 filter options are no longer on my app and seem to have been replaced with wired or wireless. Any way to change this back or is it a netgear change...
Oct 23, 2022Guru - Experienced User
What filter options are you referring too?
What app are you referring too?
What FW version are you using?
- Dogdad7Oct 23, 2022Aspirant
The filters that used to show 2.4 and 5 now show as wired or wireless on the device connected part of the nighthawk app. My FV is v1.0.11.126
- FURRYe38Oct 23, 2022Guru - Experienced User
Probably something that was removed from the app.
- michaelkenwardOct 25, 2022Guru - Experienced User
Filters? Is that in Device Manager on the mobile app?
Is this what you mean?
Devices
No app changes that I can detect.
- Dogdad7Oct 25, 2022Aspirant
Yes..yours reads 2.4 and 5 ..mine reads wired and wireless now .
