BrandonL_43
Dec 22, 2016Aspirant
"Firewall Rules" is missing from my security setting
I'm trying to adjust my inbound/outbound settings for my firewall for my Netgear N600 WNDR3400 but the only options available are "Parental Control", "Access Control", "Block Sites", "Block Services",...
Dec 22, 2016Guru - Experienced User
There is no separate section called "firewall rules".
"Block Services" is a firewall function, as are the port forwarding/port triggering features described on page 78 here: http://www.downloads.netgear.com/files/GDC/WNDR3400V3/WNDR3400v3_UM_19June2014.pdf
There are a couple of other firewall-related settings - on page 39ff in the manual - port scan and DoS protection, putting a device in the DMZ, and NAT filtering.
What are you wanting to accomplish?
