Lisamall
Oct 12, 2018Follower
Firmware Check Error
Got an email saying a new update was available. When I push “Check for Updates” in the app it says it’s checking for new firmware update then keeps saying “Firmware Check Error”
DexterJB
Nov 08, 2018NETGEAR Moderator
Hi Lisamall,
Welcome to the community!
1. What is the firmware version of the router?
2. Which app do you have installed (Genie or Nighthawk)? And what version?
3. Does the issue persist on another device where you have the app installed?
Dexter
Community Team
- Andy1973Nov 08, 2018Aspirant
I tried it on my iPhone and iPad got the same result. It’s the nighthawk ap. The version is 1.2.0.26.
The model is the r7450
- michaelkenwardNov 10, 2018Guru - Experienced User
Find the latest firmware here and install it manually:
R7450 | Product | Support | NETGEAR
The release notes tell you how to go about it.
