Tucker70
Apr 04, 2019Aspirant
Firmware update
I downloaded the new Nighthawk app for my R8500 router onto my iphone but not able to do the update it just keeps the symbol as if updating and never does. Not able to sign in, do I need to pay for ...
- Apr 04, 2019
I will try both and see if it works then, Thanks
Apr 04, 2019Guru - Experienced User
Did you try the restart or uninstall-reinstall?
Tucker70
- plemansApr 04, 2019Guru - Experienced User
Read your post a little fast. Went back to re-read. Are you attempting to update the firmware for the R8500 over the app and the app won't update the firmware?
If so, there's a couple other ways to try.
1. Log into the R8500 from the browser on your phone to see if it'll auto update from there.
2. manually update. Best to do over a hardwired connection. The link at the bottom will have the manual and firmware. You can download it manually and follow that update procedure.
https://www.netgear.com/support/product/R8500.aspx
Sorry was reading to fast and thought you were struggling to update the app.
- michaelkenwardApr 06, 2019Guru - Experienced User
That's the way to do it, but with the cautionary advice that if there are other ways to update the device, avoid using a wifi connection. Use a wired PC.
Easily done when someone posts in the apps section of this community.
They might get better replies, and find other answers, over in the appropriate section:
Nighthawk WiFi Routers
