Kazuss
Dec 21, 2017Aspirant
firmware upgreade to 6.9.1 from 6.2.2
Hello, I have an RNDU2000 device that I use since the news. I have never updated the firmware and currently I have 6.2.2 versions A message is displayed about available updates to version 6.9.1...
michaelkenward
Dec 21, 2017Guru - Experienced User
You refer to the RNDU2000. That is a ReadyNAS box, but you have put your message in the forum section for Home Networking Apps. It would be better in the ReadyNAS section:
ReadyNAS Network Storage - NETGEAR Communities
There is a manual and support for the RNDU2000 somewhere at the end of this link:
>>>> RNDU2000 (ReadyNAS Ultra 2) | Product | Support | NETGEAR <<<<
I see nothing about firmware there. Are you sure this is the device you need to update?
- KazussDec 21, 2017Aspirant
When I log in, I have information on the device as in the attachment
- michaelkenwardDec 21, 2017Guru - Experienced User
Looks more like an OS update than firmware.
Try this:
Plug in your model number, RNDU2000.
In that case, why the device sends me back to the description of the update from the link:
https://kb.netgear.com/000051531/ReadyNAS-OS-6-Software-Version-6-9-1
