Royalblue's avatar
Aug 26, 2015
ftp timeout
Hello,
I have just installed an N600 router and I am now having problems connecting to my website hosts ftp site I have tried disconnecting firewall and anti virus but get the same problem.
I am able to connect to the FTP server but no files appear and I get the following message:
COMMAND:> [8/26/2015 6:17:43 PM] REST 0
[8/26/2015 6:17:43 PM] 350 Restarting at 0
COMMAND:> [8/26/2015 6:17:43 PM] PASV
[8/26/2015 6:17:43 PM] 227 Entering Passive Mode (50,87,53,45,156,175)
COMMAND:> [8/26/2015 6:17:43 PM] LIST
STATUS:> [8/26/2015 6:17:43 PM] Connecting FTP data socket... 50.87.53.45:40111...
[8/26/2015 6:17:44 PM] 150 Accepted data connection
ERROR:> [8/26/2015 6:18:44 PM] Timeout (60000 ms) occurred on receiving data from the server.
[8/26/2015 6:18:45 PM] 226-Options: -a -l
226 44 matches total
  • I've had a good look at other ftp problem threads but haven't found anything that quite matches my problem above. Does anyone have any ideas?
    Thank you.
    • Royalblue's avatar
      Royalblue
      Tutor
      Obviously no one has a clue about this then. The solution was easy I dumped the Netgear router and installed a BT Home hub.... problem solved.
