Brice123
Mar 23, 2022Tutor
General streaming device???
I keep getting a generic streaming device. I have no clue what it belongs to. Has anyone figured out this issue?
Brice123
Mar 23, 2022Tutor
No wife's phone is labeled and I am not home. This happened on another AC1700. This is now the 3rd one replaced my Netgear. I don't understand what it could be. 1st one I had showed "Generic Streaming service" the second did not. Now the new one about a week old is showing that.
Mar 23, 2022Guru - Experienced User
you should be able to click on it and gets its mac address and ip address.
You might be able to find what it is with the mac address. There's plenty of mac address lookup tools online
- Brice123Mar 23, 2022Tutor
I have went through all my devices Mac and IP address. Never thought about checking a Mac online. How do you do that?
Just tried a random mac look up on google. No luck. nothing comes up.
- plemansMar 23, 2022Guru - Experienced User
it looks like its connected via wifi. Change your wifi ssid and/or password.
then connect your devices one by one and see which one shows up.
Or maybe its a neighbor with your access info.
- Brice123Mar 29, 2022Tutor
Thanks. Now for the past week I have been getting kicked off and have to restart every night around 9PM before I call them. Any fixes for this?
- plemansMar 29, 2022Guru - Experienced User
If this is a new issue, lets start a new thread to prevent confusion.
Go over what actual router you have, the modem its connected to, firmware on the router, etc
I started a new thread. thanks
