Patolnik
Feb 26, 2017Follower
Genie - bug - username change
On new version of Genie app for iOS there is a problem while login onto router. It is imposible to change the username from the original 'admin' one. So if I had selected a different name before there is no chance for mr to log into it. Thanks for help.
1 Reply
That is the hard-wired username to get at the router's controls. You can't change it.
It is not the username for Netgear's on-line thing, or for your wifi devices.
So if I had selected a different name before there is no chance for mr to log into it.You can't have a different name so that won't happen.
