shawn53913
Dec 16, 2016Initiate
Genie - Parental Controls, cannot change settings on individual devices in the network map
I set the default for parental controls to High during initial setup on the router. Then in the network map area, I tried to change the settings per user device, but when I click apply, the settings ...
DexterJB
Dec 25, 2016NETGEAR Moderator
Hi shawn53913,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Harangen
Dec 28, 2016Initiate
Hi,
I have the same problem.
I'm unable to change the settings for each device, neither from PC or from iPhone app.
iPhone app gives me at least an error message "PC_Remind_SetFailed".
The PC application "Netgear geni" version 2.4.36 on Windows 10 (which crashes all the time).
Model R7000 newest firmware 1.0.7.6.
Changes I have set earlier with an older firmware and older Geni app is still there, but changing any new devices fails.
