shawn53913
Dec 16, 2016Initiate
Genie - Parental Controls, cannot change settings on individual devices in the network map
I set the default for parental controls to High during initial setup on the router. Then in the network map area, I tried to change the settings per user device, but when I click apply, the settings ...
skiddles6969
Dec 30, 2016Aspirant
I'm having the same issue l.I have tried to change individual parental controls on both the app and the pc and it doesn't work. It was working great up until this week. I've tried uninstallin the app and reinstalling and that didn't work either. Please help!
DexterJB
Jan 02, 2017NETGEAR Moderator
Hi Jenhedr,
1. Do the unused/inactive devices still show up on the Network Map?
2. Have you tried uninstalling then re-installing the app/program?
3. Is the behavior the same no matter what device you use to individually set a filtering level?
Dexter
Community Team
