shawn53913
Dec 16, 2016Initiate
Genie - Parental Controls, cannot change settings on individual devices in the network map
I set the default for parental controls to High during initial setup on the router. Then in the network map area, I tried to change the settings per user device, but when I click apply, the settings ...
skiddles6969
Dec 30, 2016Aspirant
I'm having the same issue l.I have tried to change individual parental controls on both the app and the pc and it doesn't work. It was working great up until this week. I've tried uninstallin the app and reinstalling and that didn't work either. Please help!
DexterJB
Jan 02, 2017NETGEAR Moderator
Hi skiddles6969,
1. What is the model number and firmware version of your device?
2. What error message are you getting?
3. Have you tried disabling and re-enabling Parental Controls?
4. Have you tried resetting the device?
Dexter
Community Team
- HarangenJan 03, 2017Initiate
Hi,
Product: R7000
Current Firmware: 1.0.5.70_1.1.91 (after resetting everything)
Previous Firmware: 1.0.7.6_1.1.99
No error messages, the device changes back to "default router" instead of none.
Yes, in all possible ways, including creating a new OpenDNS account.
Yes, I have uninstalled, installed, and reinstalled Netgear Geni on iphone, ipad, and two windows computers with the same issue.
I have changed/downgraded the firmware did not work either.
I have reset the router, and now I’m able to. This resultet in a lot of work with a household of 12 apple devices, 4 printers, 10+ computers.
I do not know/dear to upgrade the router with the latest firmware in case that messes things up again, after many hours of cleaning up.
I have also had this behavior earlier, but then it helped to use the iPad software.
I have used serveral different versions/revisions of the Netgear Geni, but some fails on Windows 10,
Cheers, Roger
