shawn53913
Dec 16, 2016Initiate
Genie - Parental Controls, cannot change settings on individual devices in the network map
I set the default for parental controls to High during initial setup on the router. Then in the network map area, I tried to change the settings per user device, but when I click apply, the settings ...
Jenhedr
Dec 29, 2016Initiate
I had this same problem, and then finally figured out that you can only change the settings of 10 devices to anything other than default.
Past 10 devices and they will just keep reverting to default. You'll have to change a different device to default.
It's a really terrible set up.
I'm trying to figure out how to erase old devices that are no longer being used and that I don't have access to.
Very frustrating.
Very frustrating.
Darryl_Gittins
Jun 22, 2017Tutor
Is this really true? Has someone at Netgear verified this? This would make the app pretty much useless.
