rtdeloatch
Feb 24, 2017Aspirant
Genie: 2.4.2 Device-based parental controls filtering keeps reverting back to "Default"
This problem still persists again. A previous fix was made, but I am having the same issue with Genie verison 2.4.22 for MAC, using the wireless N router. The deve-based parrental controls do not per...
- Mar 02, 2017
Hi rtdeloatch,
1. What is the model number and firmware version of your device?
2. Please try setting the filtering level on another device (iOS, Android, another computer).
Dexter
Community Team
DexterJB
Mar 05, 2017NETGEAR Moderator
Hi rtdeloatch,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
