rtdeloatch's avatar
rtdeloatch
Genie: 2.4.2 Device-based parental controls filtering keeps reverting back to "Default"
This problem still persists again. A previous fix was made, but I am having the same issue with Genie verison 2.4.22 for MAC, using the wireless N router. The deve-based parrental controls do not per...
  • DexterJB's avatar
    Mar 02, 2017
    Hi rtdeloatch,
    1. What is the model number and firmware version of your device?
    2. Please try setting the filtering level on another device (iOS, Android, another computer).
    Dexter
    Community Team
