gadingan26
Jan 05, 2016Follower
Genie and Windows 10
There are tons of discussions talking about this. I WAS using a really old HP pavillion running on windows vist and it worked properly, but as of right now I am using a Dell XPS with windows 10 and i...
michaelkenward
Jan 06, 2016Guru - Experienced User
I have seen suggestions about trying an older version of the Netgear Genie.
- DexterJBJan 06, 2016NETGEAR Moderator
Hi gadingan26,
We are currently investigating this issue with some Windows 10 devices. You may use the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
Dexter
Community Team
- Archon-Jan 07, 2016Aspirant
Hope this helps. Win10x64. build 10586. Dell e7450 8GB. Latest version of genie quits immediately after splash screen appears. Windows error log:
Log Name: Application
Source: Application Error
Date: 1/7/2016 9:14:23 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: MyPc
Description:
Faulting application name: NETGEARGenie.exe, version: 2.3.1.0, time stamp: 0x55ba05d8
Faulting module name: wpcap.dll, version: 4.1.0.2001, time stamp: 0x4c24dd97
Exception code: 0xc0000005
Fault offset: 0x0001b345
Faulting process id: 0x27a8
Faulting application start time: 0x01d149ba47a50ce5
Faulting application path: C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe
Faulting module path: C:\WINDOWS\SYSTEM32\wpcap.dll
Report Id: 385d3859-7229-4de2-9504-c778b3058828
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2016-01-08T02:14:23.394756300Z" />
<EventRecordID>7035</EventRecordID>
<Channel>Application</Channel>
<Computer>MyPc</Computer>
<Security />
</System>
<EventData>
<Data>NETGEARGenie.exe</Data>
<Data>2.3.1.0</Data>
<Data>55ba05d8</Data>
<Data>wpcap.dll</Data>
<Data>4.1.0.2001</Data>
<Data>4c24dd97</Data>
<Data>c0000005</Data>
<Data>0001b345</Data>
<Data>27a8</Data>
<Data>01d149ba47a50ce5</Data>
<Data>C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe</Data>
<Data>C:\WINDOWS\SYSTEM32\wpcap.dll</Data>
<Data>385d3859-7229-4de2-9504-c778b3058828</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event> - Tyler1701Jan 08, 2016Initiate
Come on Netgear I can see my Nighthawk 6700 finding it's way in the local rubish heap. Based upon post warrenty support I wouldn't give Netgear a 1/2 star rating. I had a belkin router and thought I was up grading. I was sure fooled by Netgear and and Costco.
Genie won't work on windows 10 I can get online but I can't control it through genie. I was told when I bought it last March this is the best router out there.
Maybe it was now with Windows 10 they are the worst!!!!!!!! The only person I'd recommend a Netgear product to the Chinese maybe it would slow them down in hacking into the worlds systems
- michaelkenwardJan 09, 2016Guru - Experienced User
Did you read, and try the advice of, the post a few above yours from DexterJB? Maybe the older version of the Genie will work for you.
I do not use Netgear Genie, if you mean the standalone program, to control things. I use the web interface and my browser.
- spike7447Mar 16, 2016Aspirant
when i diagnose the genie application, it says that the genie is incompatable with windows 10 x64
i also have the app with my Iphone, so i can still have control there, but i'd like it to run on my computer again
OS Name Microsoft Windows 10 Home
Version 10.0.10586 Build 10586
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name SPIKE
System Manufacturer ASUS
System Model All Series
System Type x64-based PC
System SKU All
Processor Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz, 3501 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1901, 8/10/2015
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume4
Locale United States
Hardware Abstraction Layer Version = "10.0.10586.0"
User Name SPIKE\JimBob
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 28.1 GB
Total Virtual Memory 36.7 GB
Available Virtual Memory 32.6 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes- michaelkenwardMar 16, 2016Guru - Experienced User
Did you try using the previous version of the Netgear Genie?
DexterJB posted a link earlier on in this discussion:
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92e E81a20xRjg/view?usp=sharing
There is also a long discussion, including a few tips and tricks, here:
netgear genie not compatible with windows 10? - NETGEAR Communities
Look for another message in there from DexterJB with a possible workaround to get the new version of Netgear Genie to work in Windows 10:
