gadingan26
Jan 06, 2016Follower
Genie and Windows 10
There are tons of discussions talking about this. I WAS using a really old HP pavillion running on windows vist and it worked properly, but as of right now I am using a Dell XPS with windows 10 and i...
Tyler1701
Jan 09, 2016Initiate
Come on Netgear I can see my Nighthawk 6700 finding it's way in the local rubish heap. Based upon post warrenty support I wouldn't give Netgear a 1/2 star rating. I had a belkin router and thought I was up grading. I was sure fooled by Netgear and and Costco.
Genie won't work on windows 10 I can get online but I can't control it through genie. I was told when I bought it last March this is the best router out there.
Maybe it was now with Windows 10 they are the worst!!!!!!!! The only person I'd recommend a Netgear product to the Chinese maybe it would slow them down in hacking into the worlds systems
michaelkenward
Jan 09, 2016Guru - Experienced User
Did you read, and try the advice of, the post a few above yours from DexterJB? Maybe the older version of the Genie will work for you.
I do not use Netgear Genie, if you mean the standalone program, to control things. I use the web interface and my browser.
