stestardi
Apr 04, 2017Aspirant
Genie App Not Available for Galaxy Tab 4
I recently reset my Samsung Galaxy Tab 4, and when I tried to install the Genie App from the Play Store there is no Install option and I see the message "Your device isn't compatible with this version".
will this be fixed, and if not is there a way to install the old version that was compatible with the Tab 4?
Thanks!
- DexterJBNETGEAR Moderator
Hi stestardi,
You can try the using the previous version linked below and have it updated if possible.
http://files.netgear-support.com/go/?a=d&i=FjCF9cAIvR
Dexter
Community Team
