velnias
Mar 03, 2015Novice
Genie App not working after FW upgrade 1.04.18_1.1.52
Been searching the forum for this elsewhere and haven't found any reference to it, so apologies in advance if it's been mentioned elsewhere. After upgrade to 1.04.18_1.1.52, Netgear Genie app on my...
HiSpeed
Mar 03, 2015Guide
Velnias, Netgear Genie on Android is not good, I mean it doesn't work properly with the R7000 firmware.
I've been obliged to delete it definitely after I saw some parameters erased without reason into my R7000.
Use a direct access instead.
