TonyPHX
Apr 18, 2017Guide
Genie App says remote access not supported for my router?
I have an R9000 X10 and in many documents it says that Genie should be able to support remote access for this router. Yet, the Genie app (latest version) on iPhone says my router does not support re...
- Jan 22, 2018
Hi dereksoderquist,
Yes, the WNDR3400v2 does support the NETGEAR Genie app but is not among the supported devices for the Remote Login feature. The link below indicates the supported models.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
TonyPHX
Apr 18, 2017Guide
Never mind. Uninstalled Genie, rebooted phone and router...reinstalled Genie. Totally different experience. : )
- ElaineMApr 19, 2017NETGEAR Employee Retired
Is it working now?
- TonyPHXApr 19, 2017Guide
Yes, all working now, perfect!
- Fatherof390Oct 06, 2017AspirantI'm having the exact same problem with my nightgown 2350. I tried uninstalling the app and reinstalling it and nothing changed.
- mwseymourJul 08, 2017Aspirant
Hi,
I am also experiencing the same error. I have uninstalled the Genie iOS App and reinstalled, Router Firmware version
v1.1.00.26 and Geniw Version 3.1.28 but same problem.
I enabled Remote Management in the Advanced Setup section but when I try and enable Remote Access in Genie
I get the message This router does not support remote access which is not true.
Any assistance will be most appreciated.
- Redtulips7Apr 19, 2017Luminary
What do you mean by remote access? Beyond WiFi range? I am only capable of accessing Router through Genie App with my Note 5(Android 7.0) while in the WiFi range!!!!!!
By remote I just mean remote via Genie. The "remote access" url also works, but I was trying to make the Genie app work right from outside of my network. And of course I wanted to add the Alexa skill for Netgear. Very cool. : )
Remote doesn't necessary mean access through WiFi!!! Can you access your Router without WiFi or way from home location?
