TonyPHX
Apr 18, 2017Guide
Genie App says remote access not supported for my router?
I have an R9000 X10 and in many documents it says that Genie should be able to support remote access for this router. Yet, the Genie app (latest version) on iPhone says my router does not support re...
- Jan 22, 2018
Hi dereksoderquist,
Yes, the WNDR3400v2 does support the NETGEAR Genie app but is not among the supported devices for the Remote Login feature. The link below indicates the supported models.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
Redtulips7
Apr 19, 2017Luminary
What do you mean by remote access? Beyond WiFi range? I am only capable of accessing Router through Genie App with my Note 5(Android 7.0) while in the WiFi range!!!!!!
TonyPHX
Apr 19, 2017Guide
By remote I just mean remote via Genie. The "remote access" url also works, but I was trying to make the Genie app work right from outside of my network. And of course I wanted to add the Alexa skill for Netgear. Very cool. : )
- Redtulips7Apr 19, 2017Luminary
Remote doesn't necessary mean access through WiFi!!! Can you access your Router without WiFi or way from home location?
- TonyPHXApr 19, 2017Guide
Yep. I never said remote means being on wifi. Yes, I can use the Genie app when NOT on wifi. Yes, I can use remote administration also from outside of network.
