TonyPHX
Apr 18, 2017Guide
Genie App says remote access not supported for my router?
I have an R9000 X10 and in many documents it says that Genie should be able to support remote access for this router. Yet, the Genie app (latest version) on iPhone says my router does not support re...
- Jan 23, 2018
Hi dereksoderquist,
Yes, the WNDR3400v2 does support the NETGEAR Genie app but is not among the supported devices for the Remote Login feature. The link below indicates the supported models.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
mwseymour
Jul 28, 2017Aspirant
Thanks Dexter, but I am unable to use this feature due to it not being supported on this model of router. Unless you have another solution I am stuck !
Regards
Malcolm
Regards
Malcolm
DexterJB
Aug 17, 2017NETGEAR Moderator
Hi Fightonuscjck,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- FightonuscjckAug 17, 2017TutorI am still havingthe problem. Rather than trouble shooting it would be nice for Netgear to reproduce the problem and provide definite solution versus a try this and that approach. Thank you
- lacieppersonAug 17, 2017AspirantYes, I am still having this problem.
- daboudreauSep 05, 2017Aspirant
When I try to enable remote access I get "Does not support Remote Access". What I am I doing wrong?
Dan
- daboudreauSep 06, 2017Aspirant
I was able to turn on the remote access through the regular web management interface, and I was also able to use the provided remote access https address in my web browser. So my router does support remote access, but it seems that the "genie" version isn't able to.
Dan
