BizLorax
Aug 22, 2015Star
Genie app won't connect to OpenDNS
Just tried using parental controls in Genie App but it will never connect to OpenDNS during the setup process. I have now created two accounts in OpenDNS and the accounts work fine at the OpenDNS we...
rock_roller
Oct 24, 2015Initiate
maybe you should let your other techs know about this instead of having customers on the phone for hours troubleshooting something that currently has no fix. I will have to return this R8000 and exchange for ASUS, as my old one worked perfectly for parental controls.(unless Netgear comes up with a "quickfix" soon)
KHouse
Oct 24, 2015Aspirant
so frustrated by this also - I purchased a linksys last month and found out the parental controls consisted of me blocking up to 8 sites by manually putting them in - not helpful - so I just purchased this NightHawk because it looked like the parental controls were stellar - now I get all this work done on it (purchase, install, set up, download genie etc..) and it won't work - I cant get it to sign in! I'm so frustrated. can't believe it doesnt even work! I have the r7000. pulling my hair out right now - whats left of it...
- DexterJBOct 26, 2015NETGEAR Moderator
Hi KHouse,
We apologize for the inconvenience that this situation has caused you. Engineering is already working on a fix for this. In the mean time, I recommend logging in to your OpenDNS account using an iOS or MAC OS X device for you to manage your LPC settings.
Dexter
Community Team
- KHouseOct 30, 2015Aspirant
dear all - just got a message from opendns and they said its now fixed - I went in to check and what-do-you-know - it works now. thanks for all your help, encouragment and voice!
- BizLoraxOct 31, 2015Star
I just retried launching genie app on my android and from PC app and genie will still not accept my OpenDNS password (but the same p/w works fine at OpenDNS website).
I haven't yet tried the fully automated router setup suggested by someone else, affraid it will mess-up my internet connection entirely. When I have more time I'll try that.
But as it stands genie is a complete dud for me.
