justwondering01
Oct 13, 2015Aspirant
Genie app won't connect to OpenDNS
I am trying to useGenie Parental controls and when I attempt to login to my OpenDNS I get the following error "There was an error signing, in please make sure you're connected to the Internet and tr...
- Nov 02, 2016
Got it to work! In the end, it looks like the router did not reset properly when it was shut down. So I unplugged it, then put the power switch to on/of 4 or 5 times (to discharge the capacitors), then plugged the power cord back in. Once fully booted, the Genie app was able to talk to the router on the first try. What is wierd is that in the last weeks, all other devices must have contuinued to work with the Genie app since Parental Control/by-pass account was still working fine...
Weird one...
Anyway, thanks for your help Dexter! And I hope this is of use to someone... :)
DexterJB
Oct 13, 2015NETGEAR Moderator
Hi justwondering01,
Have you tried using other devices (other computer, smartphone, tablet)?
Dexter
Community Team
justwondering01
Oct 18, 2015Aspirant
I tried two other computers and I get the same error. If I put the wrong user name and password I get the "Opps, we don't recoginize that user name or password" error. So I know it is looking at the OpenDNS info.
- DexterJBOct 19, 2015NETGEAR Moderator
Hi justwondering01,
1. Please try using a mobile device and install the NETGEAR Genie app.
2. What is the operating system of the computers that are experiencing the issue?
3. What is the version of the NETGEAR Genie program installed on the computers?
Dexter
Community Team
- J4UOct 23, 2015Aspirant
Having the same issue on both PC W10 and Android app. The PC error (V.12 of Genie as others do not work at all)is to make sure you are connected to the internet and try again. The Android just loops back to the login screen wanting you to retry.
